Start a PC on Machine Powerup
JDCROCKETT724
Jun 2010
Michigan
249
I have a touch pc that is being used as an HMI and laser control. Does anyone know how I can power on the PC when the machine powers up instead of opening up the cabinet and pressing the power button?
Hi, you can usually set a setting in the bios so that the PC will boot when it receives external power.
You can use a little relay connected to the motherboard instead of the start button. Alternatively, if supported by the computer, you can use Wake on LAN magic packets from the PLC to turn it on. Some BIOS even support the feature of turning back on after power failure (for servers and such).
On most PCs, the start button is two wires connected to two pins. You should be able to easily wire it into a push button outside the cabinet. Only hard part will be making it look pretty.
Which is why you could just use a little relay inside the cabinet instead of a button. You can also tell if the PC has turned on if you have a 5V input (a lot of encoder/counter cards have these) by hijacking the power on LED lines. These are all just little plug connections to arrays of pins on the motherboard (to make it easy to put the mobo in whatever case you want to use).
Hello Everyone! It has been a while since I used the method of drawing a state diagram, converting that to Boolean algebra, and translating that...
2,972
I would like to build a gas engine pull start test machine. I envision a electric motor with a large cam or pulley. Pulley diameter would be...
2,690
I am loading Intouch 10.1 on a test machine with Windows 7 and I have everything working except for Alarm Printer. The standard .bat file we use...
5,366
I have been doing a scada system for a year+ as of right now and have come across a problem that I have bandaided but am sure there are better...
7,025
Conc.: A control mechanism (eye) tells the PLC - with the aid of a timer - whether or not goods have passed within 8 sec. If not, machine must...
8,809
