FrankBerends
Hi folks,
As an enthusiast beginner in PLC programming (Click PLC), I'm already for days struggling to find a solution for this:
I want a momentary PB (X1) to start a timer that starts a pump (coil Y1). The timer is set to 5 min. and then the pump stops. But when the tank is empty before the 5 min. have ended, I want to kill the process by the same PB (x1).
Thanks to this forum I managed to program one button start/stop actions (with set/reset) and I learned to program the timer thing (reversed TON). Now I want to combine these two. But so far I only managed to do the thing with a PB2 (X2) as a kill switch. I won't bother you with the numerous setups I tried (and failed), but I will share the best I made till now. The next step is to change PB2 to PB1 as well.
Appreciate your help!
(btw, Y2 is LED ring of PB1)
