Static electricity help
2004sk4
May 2005
Georgia
172
Is there any product available that can limit the amount of static electricity generated by 23000 colors and 15000 cottons that are on a loom. The problem the static causes is the drop wires(which tell when a cotton or color it out) are induced with voltage which cut the loom off.
We were told some kind of deinonizer would work but we need one that will cover a 15 foot wide grid.
kevin
kevin
It called WATER. :)
Back when I worked in injection molding, we used Simco ionizing blowers to eliminate the static charge on CD jewel cases. They have static control bars that may be appropriate for your application... :confused:
They just so happen to be available up to 15' long as well!... (y)
-Eric
For film overwrapping operations - I use a unit known as the "Meach" static eliminator - a little high voltage unit and a set of fingers , works very well .
www.meech.com
Hi, Does anyone have any experience with hydraulic fluid static electricity affecting electronics?
1,774
We are currently haveing an issue with static on our line. We make a paper product that gets cut and as it passes out of the saw house it picks up...
4,210
guys: I have a problem with my IP configuration. my organization networking has 2 subnets. 10.0.0.25 and 10.1.0.25 both under 255.255.255.0 all...
567
Hi Yes, I'm stuck again. Trying to define a Function Block. What I've put in there so far has been a straight copy/paste from the code (and that...
22
2,900
Hi; In our Corrugator plant, there are automatic WIP conveyors having two moving carts also. System contains 17 items (server, two PCs, Siemens...
2,444
