Stationary Carbon Monoxide detector
Christoff84
Jun 2006
Cambridge, ON
407
Hi folks, does anyone have any recommendations for a stationary CO detector. Ideally I'd like them to have ethernet based communications (Modbus TCP), but I can work with serial if I really have to.
From my experience with fixed point gas monitors, you're either going to have a simple 2-wire monitor that is easy to maintain/calibrate AND (relatively) cheap or a packaged system that is either easy to maintain/calibrate OR cheap.
Here's one I found, but I have no experience with that brand.
https://www.sensidynegasdetection.c...trollers/model-7200-gas-detection-controller/
If it was me, I'd go with a Draeger, MSA, or Honeywell monitor using 4-20 mA and then get a converter to send it via the ethernet if that's what you need:
https://www.datexel.com/4-20-ma-to-modbus-tcp-dat8015.html
Thanks for the help. I think I will have to look for a 4-20ma device and connect it that way. The only Modbus/TCP device I found doesn't require any kind of calibration or bump test, so not sure I trust the quality of it.
Sorry if this question isn't entirely PLC related, but I started an internship this summer and was recently given a project to work on for the...
17
5,797
I am involved in a huge project where we will place 30 to 50 panels on top of the roof of a building in SC. We wanted Stainless Steel, but we are...
2,262
Dear, concerning the attached, clause 7.12.7.2, how the detection of hydrocarbons in the tunnel drainage effluent is understood? Do we need to...
2,856
I was wondering if anybody had any experience with carbon monoxide meters. Just the handheld type offerings from Fluke, Snifit and the like. It...
2,483
