gas meters
We have used Idustrial Scientific multi-gas meters for monitoring Methane, CO2, CO, Hydrogen Sulfide, O2 etc. These work well and have alarms, peak readings, data logging etc. They are also approved for hazardous location use which is a must for where we use them. Idustrial Scientific is coming out with small single gas monitors that are portable, light and cheap (about $100). We got use of some demo units about 6 months ago but I am not sure if they are on the market, I think so but am not sure.
We also have contnuous monitoring requirements for which we use Draeger units. Some things to be aware of... the IR units from Draeger are good but you can get bad readings if you deploy them near VFDs. Draeger has other units that are not IR and these do not have the same problems with VFDs. Also there are cross-sensitivity issues that you should look into... I don't remember them all with CO but accetlyne causes problems with CO2 and I think the hydrogen sulfide can cause problems as well. The gas meter manufacturer should be able to provide you with all the necessary info though. They sometimes have filters that help reduce cross-sensitivity and protect the actual sensor portion of the unit.
One more thing, gas meters generally do not work well when pressurized. Not sure if this applies to you or not but check into it if you have to work with these under pressure.
Hope this helps...
