Steeplechase and Logix
cking2729
Jul 2014
texas
Hello,
I am working with a customer who is hoping to interface Steeplechase VLC with a Logix processor. Steeplechase will need to be able to access tag data from the Logix processor, either by Steeplechase reading or Logix writing. It doesn't really matter which comm protocol is used....be it DeviceNet, EtherNet/IP......even OPC is a possibility if it is somehow able to get the data into Steeplechase.
I am by no means a Steeplechase expert, but I can work my way around it. I'm hoping someone here has info or experience on how I could configure getting data between the two. If perhaps anyone knows how to set up a write message in Logix to Steeplechase....or set up Steeplechase to access the data via a DeviceNet, EtherNet, etc...that would be TREMENDOUSLY helpful!
I've only replaced Steeplechase systems and never had to commission new but they still pop up every once in a while and are still in business here in Ann Arbor. I would call them at 734-975-8100.
We've run into an old system that we are upgrading which is still running Steeplechase with Citect using Devicenet to Wago. I had some experience...
159
Is there anyone out there still using Steeplechase VLC?
2,659
Hi! I got a problem concerning Steeplechase VLC. A customer has a station controlled by it, now I´m asked to do some changed regarding the HMI...
5,029
I have a cust. that needs mods to there Steeplechase VLC program on one of there mach.s, but an unhappy maint. worker that is no longer working...
1,842
I am converting TWO machines that have two racks each (one complimentary 16 slot rack and one straight 8 slot rack each) into ONE...
7,189
