Step 5 Timer
clarke24
Nov 2004
uk liverpool
Hi, I want to change the KT value of a timer in Step 5 V1.1 but I don't know how to do it either online or offline. Can anyone explain how to do it. Thanks
If the timer uses a KT value directly then you need to edit that page and change the timer value to the new one and save the project and then download to the PLC.
Hi, Thanks for the replies. I have attached a picture of the timer i want to change. I want to change the value in TV from 17 to 10 but i cant figure out how to do it. Could you explain the procedure.
Press F6, navigate the highlighted area to KT 017.1 and write "KT 010.1" then press F7 to save and then press F7 again to download to PLC.
Hello| I have Step 7 1200 and using a timer to operate a relay, currently the relay remains closed for 1MS. I need the relay to close for only...
25
8,884
can you help me with this one guys using fluid sim. This is for my bring home exam. providing a problem description, schematic...
2,461
I am working on a new View ME project for a demonstration display using a PC Hosted version of ME Station. I would like to show a cylinder...
3,172
Hi, I have a simple function block that does not function when I use multi instance SFB4 IEC Timer On Delay. I could not attached a zip of the...
9,100
Hi all, I have an FB that I've created that uses a timer. At the moment I've just given it an address (T 71) but I'd like to be able to pass...
2,969
