STEP 7 V5.5 SP4 HF11 with TIA, VERY SLOW
Kasperv79
Mar 2012
Copenhagen
48
Hi guys.
Since I installed TIA portal on my windows 7 64 bit virtual machine, the Classig step 7 V5.5 SP4 HF11 got VERY slow, ctrl-D for online status takes 10 sec..
gooing online on Graph, is almost not possible.. at least it takes 30 sec.. en freezes every time I trying to scroll.
I have two virtual machines, one with TIA V13 and another with TIA V14, same problem...
I only tryid with ethernet connection and not with a MPI/DP adapter.
theres no services taking memory or CPU, så I dont think its a ressource problem.
any ideas?
I should have added, If you are AVG added a 'Feature' to scan virtual machines. Go to Menu==>Settings==>Troubleshooting and disable @Enable hardware-assisted virtualization.
I brought my VM's to a virtual (forgive the pun) standstill.
Br
steve
VM settings? how much ram and cpu cores do you have set?
host config?
Usually I make TIA Portal VMs with 2 cpu cores and at least 4GB of ram. More than 4GB of ram when I need to open multi istances of TIA/S7.
If the resources are not a problem, try to poweroff the VM, defrag and compact.
Sometimes it happens that the VM become very slow.
Thanks for your supply's.
4GB ram 4 cores (host is 8 gb with i7)
the problem is also after i uninstalled TIA V13. So I think its a bug somewhere..
Also when i try to copy some project to a USB it transfer with about 2-300 kb/sec.... :/
FOLLOW UP:
I tryid with a MPI/DP adapter and everything worked fast again..
Then i Saved with "regeneration" checked and that solved the problem. Now online with ethernet connection as is fast again :)
Such a basic Siemens question, but I don't know who to ask. I have a customer who needs help with a Siemens S7-300. They have a tech in Italy...
2,202
Hi guys, i installed step 7 v5.4 sp1, then v5.4 sp4... then i copied the license keys from another pc which works well step 7 v5.4 sp4. But my...
9,509
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
214
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
266
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
359
