step7 300 scl source code
mad@imap
Apr 2008
Columbus, Ohio
25
Hello all, I have a fc block that is in SCL from one proj that I would like to put in another. I've read about the source code file wich I can get from the proj. But I can't figer out what to do with it. when I copy it into the source folder and then try to compil I get this ERROR "symbolic block name: 'FC_DWORD_TEST' not recognized. I've already added the fc block into the block folder.
any help would be great thanks.:geek:
Just wondering if anyone has managed to set up safety Comms between two safety s7-300 controllers. With one programmed via Tia portal and one...
2,166
Welcome every body. how do siwarex module FTA have Calibration ?????? thanks
2,250
I've tried few options to upload data from the cpu (WITHOUT having to stop/run the cpu again, but struggle a bit. Please help-out if you can! My...
3,963
I am new to Seimens and am having trouble with the SCADA portion of my project. This is completely different than any Rockwell/GE/WW software I...
6,319
Hello everybody! I have a simple question, but I don´t found the answer. I have a ET200M a IM153-2. It is possible connect anything inputs cards...
1,931
