Hardware Simatic Step7-300
jm76
Oct 2009
Barcelona
29
Hello everybody!
I have a simple question, but I don´t found the answer.
I have a ET200M a IM153-2. It is possible connect anything inputs cards or output cards to this IM153-2 or only is possible connect the hardware specific that belong this card.
When I configured the hardware with HWConfig this is possible, but I don´t know sure.
Thanks advanced and I hope some reply.
First I wrote here on the forum and then search the other forum for any similar topic. And I ask.
You can see the time.
Jesper, do remind me never to answer PMs of this kind again, as I did just before entering the forum.
Regards,
etoman31 said:
hi everybody !
I am trying on a project and I need CP343-1 Advanced Java Applets .please help me ! this is my e-mail adress: [email protected]
Pleas don't hijack threads. This subject is not in the scope of this thread, so you better start a new thread.
Regards,
Hi everybody, Does anyone know how to upload hardware configuration from PLC to PC in SIMATIC STEP7. I'am using S7-400 does it make the plc stop...
8,352
Hi, Weird problem: I have downloaded the hardware config, but when we do a compare the SDB differs: We have this issue on several PLC's...
1,348
Hi, Something weird in simatic: Hardware differs. So I downloaded the hardware config form the s7 hardware configurator after save and compile...
1,888
Hi When I am trying to import data from EPLAN after configuring in EPLAN Electric P8 Simatic manager is showing the error Parent Object Does Not...
3,351
I have an 1769-L16ER that I use to test code and I just found that I can't create MSG tags at the local program scope - they have to be done at...
195
