STEP7 : Multi-instance inside a Multi-instance
Yves
Jan 2008
Vielsalm
Hi everyone,
Have somebody already programmed in STEP7 a multi-instance inside a multi-instance? I have problem with parameter IN, OUT, and IN-OUT.
A little schematic of what I have for best understanding :
FB1
STAT:
MOTOR1 FB100 --- Instance 1 of FB1
MOTOR2 FB100 --- Instance 2 of FB1
FB100
STAT:
POSITION FB200 --- Instance 1 of FB100
REGULATOR FB201 --- Instance 2 of FB100
My problem is that I habe IN, OUT, IN-OUT variable in FB200 and FB201 and I can't see them when I call Instance MOTOR1 in FB1.
How can I join those IN, OUT, IN-OUT variable?
I wanted to have something like this :
FB1:
Call MOTOR1
POSITION
REGULATOR
Call MOTOR2
POSITION
REGULATOR
Is it really possible?
Thanks for all ideas.
Yves.
You will see the parameters from within the Instance DB of the original called block, i.e, FB1.
Inside that IDB, it should include all instances of FB100 that you have called, and from there you can expand and find FB200 and FB201.
You need to add the variables to the interface of FB100 and then pass them on to FB200/201
Hello All, I have a problem wih monitoring variables when multiple instances of an FB are called within another FB in Step7 SCL. 1. I create FB61...
8,548
Hi all! I have one question: How do i create in a STEP7 GRAPH object in which more than one (2,3...) sequence running? Thx!
1,945
I need to send messages via Ethernet to one Station in a Multi-Project from all the other Stations in the Multi-Project. It tuurned out that one...
1,683
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
162
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
156
