Step7 - ProTool, how to compare Runtime and Offline programs
RMA
Sep 2004
North of Hamburg, Germany
2,052
I'm probably going to need to modify the ProTool program for a TP170B in the near future. Looking at the program as stored in the copy of the project I've been given to work with, I don't believe that the offline version of the ProTool program can possibly work. Before I screw up a working Runtime program, is there any way I can compare the Online and Offline versions of the program (similar to the Online-Offline compare facility in Step7)? Alternatively, is there any way I can upload the current Runtime program from the panel, so as to at least compare it manually?
Cheers
Roy
You can allways take an image of the panel. Either via Prosave or with a flashcard. Then you have a backup that you can restore if need be.
You can also repeat it with the current project that you have. Download it and then take an image. Then compare the images.
Somewhere on the panel, there is an .fwd (Protool) or .fwx (Flexible) file. If you can locate it, then that is what you shall compare.
Activate the Taskbar and then Windows Explorer.
Under My Computer \ Flash \ Simatic \ .. you will find the PDATA.FWX file. This is the one to compare.
edit: I just notice now that you specified Protool in the thread header. Not sure what the filename is, but the extension is .FWD.
You can see the extensions with View .. Options .. then deselect "Hide file extensions".
Thanks Jesper, I remember the .fwd file from the Rossendorf project.
Is there any way to get to the Windows level other than switching power to the panel off and back on to catch it during reboot (always assuming there isn't a button for this - I haven't checked yet)?
If the original programmer was a nice guy, then he has put than function on a special maintenance screen somewhere.
In the meantime I have had the pleasure of programming an OP170B (same generation as your TP170B). And the possibility to get to the taskbar is not there as it is on an OP177B. At least I could not find it.
So I suggest that you make a complete image. You can at least get back to where you were before.
When taking an upload of the panel, u get a compiled version of your program, u can't make any changes ...
Is there a way to decompile or something ?
Anyone got protool ? I have a Step7 project and hope fully the protool HMI project is in there havent got protool though and WinCC doesnt see...
2,475
I've been asked to add a few bells and whistles to my old FZR Rossendorf project. Most of it is no real problem, but one thing that I thought...
3,268
Hy, I have the following softwares: Protool V6.0 SP2 , Simatic Manager V5.4 In the protool software, I cannot check the Protool integration in...
8,395
I'm back in Rossendorf this week, trying to make a bigger bang, as usual and I've noticed our ProTool HMI PC has developed a strange quirk...
5,816
I was just having a look through the logs in general when I noticed that the User Name of the currently logged on User isn't being stored in the...
3,492
