Stepper motor continuous run
Mr. Ro Bot
Oct 2019
at home
23
I've got an SLC500 running a 1746-hstp1 controlling a stepper motor. What's the best way to set the motor to run continuously?
I only see Jog, Relative, and Absolute move options. The best I've come up with is just running the motor in Jog for a desired time or try to do blended moves. Looking for an simpler option if there is one
Thanks!
You will have either dip switches or rotary switches on the stepper driver to adjust your motor current, you need to set it as per your needs
A quick peek on the manual found these
The first three bits (SW1,2,3) of the DIPswitch are used to set the dynamic current
You are running servo motor at a speed of 750 RPM (10000pps/800steps/rev=12.5rev/s=750RPM), from the torque curve you can see at 750RPM torque drastically reduce, so in order to get more torque you have to reduce the speed of the motor, try reducing speed to 300RPM by reducing 10kpps to 4kpps or increase micro stepping to 2000.
Remember stepper motors are suitable for low speed/high torque applications, At zero speed stepper motor give max torque as you can see in the torque curve.
My current setup uses an AC motor running at 1750 RPM. It works great, but I need to sync multiple motors and I need the ability to have a "Jog to home" after the motors stop their main run.
From the look of things I don't think a stepper motor would work for my application at that high of a speed.
What do you suggest? Would a servo motor be any better? I'm not familiar enough with servo or stepper motors, but I've had some equipment that came w/ servo motors that pulled tremendous loads at a good pace.
Yes, Servo motor will work fine for High Torque/High Speed applications but it will not be as economical as stepper motors.
Are there any Servo Motors that work best w/ SLC500 plcs? The program I'm using is pretty straightforward. Stop/start. Run at constant speed, then jog to home when stopped.
Does allen bradley make a servo motor control for the slc500s or would it have to be separate?
Addind encoders to your current motors wont work?
I'm running four motors at different speeds and loads. I'm trying to keep them synced at their specific RPMs while the loads fluctuate while running. Right now I have 3 DC motors and 1 AC motor. The issue I've run into is as the load on one motor increases the RPM lags, which starts to throw them all out of whack.
You think it might be easier to add encoders and drives to help instead? I've programmed VFDs but I've never included encoders for feedback before.
I was hoping going to stepper motors would allow for precise speed control w/ all the motors, but it's obvious to me now that they're just not strong enough for this application.
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,017
I'm controlling an Applied Motion HW23-601D using a Leadshine EM542S connected to a 2080-LC50-48QBB, using CCW, and experiencing some weird...
613
Hello. I am using the following: Eaton E4-AC-12RXP PLC I am trying to control the CL86T which controls a Closed-Loop Stepper motor. I am using...
975
Not totally PLC related, but I figured this would be a good place to ask: I have an application where 7 small parts are being gripped and then...
19
3,320
Hello all, I'm working with an s7-1200 and a stepper motor in Tia portal v17. This stepper motor is an SMD23E2 and I am attempting to connect...
19
2,852
