Stepper Power Question
Apr 2002
Just a bit northeast of nowhere
1,117
Greetings all!
I'm setting up a system with some Automation Direct stepper drives, I was wondering about the power supplies.
The system uses a STP-DRV-80100 driver and STP-MTRH-34127, a total of 4 sets. Up to two may be in motion at any given time. The motors have a nominal current of roughly 6.5 amps, and half that when idle.
I want to connect 2 power supplies in parallel to feed these beasts. The STP-PWR-4810 provides 48 VDC at 10 amps, so combined gives 20 amps. The StP-PWR-7005 provides 70 VDC at 5 amps, so total of 10 amps.
Now, according to the documentation, to get maximum torque, this requires the 70 VDC drive. Which is odd because that is the motor needs 6.5 amps, not sure where the rest of the current is coming from.
So for 4 of these, which is best: 48 volts at 20 amps or 70 volts at 10 amps?
Any thoughts?
Thanks!
Tim Moulder
Good explanation from Gecko.
There won't be a continuous load of 6.5 Amps. The large capacitor is the most important part with steppers.
I used that drive and motor combination a few years ago (one of each). The only issue was overvoltage from the power supply when it's idle. If you stop with all windings off, the unregulated voltage will rise above 80 Volts and trigger an overvoltage fault in the drive. Add a resistor across the supply to give it a little load. Don't remember what I used. Try 4700 Ohm, 3-5 Watt wirewound. You won't need this if you stop with a little current for braking.
HI everyone! I am trying to use a Micro850 to control a SureStep (Leadshine) Stepper drive (DM805-AI) from Automationdirect. I have no trouble...
192
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,061
Good Afternoon, I am hoping somebody can advise me on a make/model for a stepper drive. I have a failed ACS drive that worked wonderfully. I am...
702
I'm controlling an Applied Motion HW23-601D using a Leadshine EM542S connected to a 2080-LC50-48QBB, using CCW, and experiencing some weird...
621
Hello. I am using the following: Eaton E4-AC-12RXP PLC I am trying to control the CL86T which controls a Closed-Loop Stepper motor. I am using...
982
