Sticky Relays
I've got a 16 Allen-Bradley 700-TBR24 relays that are "sticking". 24 VDC from a PLC card drives the coil, and 120VAC is on the NO contacts drives a .4A strobe light. At times when the PLC digital output is turned off, the relay indicator goes off, but the 120VAC light remains on.
Removing the 24VDC power source from the card/coil does nothing (the light remains on), and resetting the the 120VAC does noting (the light comes back on once 120VAC is restored). The only way to turn the 120VAC light off is to pull the relay from the terminal block. When replacing the relay back into the terminal block the light stays off (as it should).
This phenomena is seen all 16 relays at time to time, so it's not just one bad relay. What is going on here?
Bill's original Quote - Removing the 24VDC power source from the card/coil does nothing (the light remains on) - Suggests that may not be the case this time - but it is possible
I have seen varied effects from electrical noise - usually with large VSD's etc in the system
Hi, I'm trying to get some ideas as to why some of our relays are not working properly. The socket is 700-HN222 from Allen Bradley and the relay...
3,771
Hello again. For years we have been using WonderWare for our HMI interfaces. Starting about a year ago we started experiencing the sticky button...
2,572
When building control panel and using sticky backs I normally drill through the little hole in the middle and tap it for a machine screw to make...
20
8,652
I've got a Factory Talk 7.0 project running on Windows 7. We are a bulk product distribution facility with 2 scales. Each scale runs on a...
5,918
I have found some logic in a PLC (90's vintage) controlling our hot oil furnace which attempts detect a stuck bit ! I think the theory was that...
2,055
