Still a little stuck (Stepper module)
Sevenfins
Sep 2019
Iowa
Stepper Module 1746-hstp1
I have read the module on this thing a couple times now. I am still not quite confident that I am understanding everything the way I am wanting to. Any point or tip in the right direction will help.
The big issue I run into is that I wont be able to hook up anything to "test" for a week or so. Otherwise I would just play with it and figure it out that way. Time doesnt ever really allow.
Which is what it looks like. The module did look pretty solid. Just wanted to see if there was anything else out there that I could read up on for extra assurance.
not really
Once you start plugging in values into the module output data files and see the motion everything should fall into place.
When you start initial testing make the the motor is disconnected from the load....
I have more memory on my cell phone than some of these top dollar plc's. memory cheap. why why why? additionally, why an M340 ethernet card...
79
27,217
Why is the configuration IP different from the actual IP address still able to run normally?
830
Just started working with some HART loops and I'm trying out Pactware.I'm using Krohne and it works just fine recognizing my modem. I downloaded...
1,368
Square D had a group that wanted to develop PLC compatible power monitoring. They worked out of the Cedar Rapids circuit breaker plant - before...
826
When a servomotor is stopped, are its three windings supplied equally with the same voltage value or close values? The servodrive is supposed to...
1,392
