Stratix 5700 - increasing amount of ports
robw53
Nov 2009
south yorks
515
Im looking into fitting the new 5700 into some of our panels and im basically looking at what is the best way to increase the amount of ports from the maximum 16(20) without having to go to a stratix 8000, im going to have 1 L33-ER, 1 PV+1000, 1 Kinetix 300, 14 22-comm-e cards, connection to a grace port, and a connection back to our network, im not sure if having two stratix 5700 with a copper connection would be ok, or if connecting the two together with the copper/SFP gigabit ports would be a better way to do this, taking into account the cost of the fiber and also the SFP's
Rob
Kindly, if we enable the routing on the Rockwell Stratix 5700 switch, as in the below link, will it cause any trouble? Like for axis motion...
157
Hi Guys, I have a Stratix 5700 managed switch that will connected to another different network thus: Stratix 1 on 10.50.3.xx >connect through...
119
Hi Folks! Could I use the Studio 5000 to read/monitoring Stratix 5700 parameters? Like switch temperature for example
383
Hi All, I've been playing with 2 stratix switches in my test bench and seeing how different configurations affect the behaviour when 2 managed...
236
Hello, I added Stratix 5700 switch (rev13.001) to Studio5000 (rev 33.02.00) as Ethernet Module but it shows mismatch/yellow triangle on the module...
280
