Stratix 5700 Redundancy configuration
Chibu
Feb 2023
Ontario
49
Hi Guys,
I have two redundant Controllogix CPUs also connected to two redundant Stratix 5700 Managed switches.
With mere Express Setup of the Stratix 5700; Controllogix Primary and Secondary change over works seamlessly; but when I configure smart ports Assignment, the Stratix switches works independently and does not allow controllogix CPUs redundancy feature.
How can I configure Redundancy in Stratix 5700 Managed switches?
There is no special “redundancy” smart port assignment. All you need is to be able to pass heartbeat packets between two Ethernet modules.
I would configure Logix connected ports as Automation Device or Multiport Automation Device on tha same VLAN.
Stratix to Stratix connection should be trunk (Switch for Automation) and make sure that Logix VLAN is included in this trunk.
There is no Stratix “redundancy feature”. If Stratix is a part of a DLR then DLR facing ports should be set for a multiport automation device. For all supported network configurations with Logix Redundancy check HIGHAV-RM002 manual. Then post your network diagram here.
Kindly, if we enable the routing on the Rockwell Stratix 5700 switch, as in the below link, will it cause any trouble? Like for axis motion...
145
Hi Guys, I have a Stratix 5700 managed switch that will connected to another different network thus: Stratix 1 on 10.50.3.xx >connect through...
116
Hi Folks! Could I use the Studio 5000 to read/monitoring Stratix 5700 parameters? Like switch temperature for example
375
Hi All, I've been playing with 2 stratix switches in my test bench and seeing how different configurations affect the behaviour when 2 managed...
230
Hello, I added Stratix 5700 switch (rev13.001) to Studio5000 (rev 33.02.00) as Ethernet Module but it shows mismatch/yellow triangle on the module...
273
