Stratix 8000 Doesn't seem to get past powerup
Cyantology
Jun 2022
Alberta
Hey,
I have a Stratix 8000 which have factory reset. When I power it on now the EIP Mod light flashes for about 10 seconds. Then all the status lights light up, turn off, and the EIP mod light starts to flash fast and nothing happens after that.
Has anyone seen this before? and know how to fix it?
Thanks in advance.
So it seems like the switch is actually getting stuck in its POST test. The switch does not show a fail, it just stays in the POST test.
You need to press reset and hold for some time during power on. As soon as the eip mode flashes, you need to release the reset button and allow it to initialize.. If nothing happens you need to repeat the procedure until it initialize properly.. This procedure is in the manual.. Just follow what is written there.. Goodluck...
I had a problem with one switch that when I changed certain settings it would put it into manual boot by setting a line in the config.text "
Manual Boot: yes"
Had to go online with the setup cable using Putty and edit that line to "no" and then type in the command "Boot"
This one got away on me and i forgot to come back to this post. We ended up just popping in a spare stratix we had.
I have tried reSeating the the CF, i have tried factory resetting the stratix multiple times, i have used a known good CF card but still none of those things managed to get the stratix pasted the POST test. I also tried letting it have roughly 24 hoursof sitting in the POST test but still nothing.
im starting to think the stratix is FUBAR'd
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
75
Hello Guys I had to reset a stratix 8000 to its defaults, but now it haves an alarm a port is flashing brown/green the message it has is not...
2,686
I have forgot password of console login When I am going to connect stratix-8000 through putty terminal,I have a username but password was given by...
1,719
I have a number of AB Stratix 8000 and 5700 switches which are passing all data but I cannot web into them nor ping them. these switches go into...
2,612
I was going through our storage area and found a Stratix 8000. I could not find an IP using an IP scan tool so I consoled into it. it appears...
1,508
