Stratix 8000 has no firmware on it
cocsbob
Jan 2016
texas
I was going through our storage area and found a Stratix 8000. I could not find an IP using an IP scan tool so I consoled into it. it appears there is no firmware on it. at switch prompt, if I type sho run it returns: Unknown cmd sho, same goes for conf t, returns Unknown cmd conf .
is this a large paperweight now or can I load firmware on it? I know I can send it in to Rockwell but cost might be prohibitive vs new switch.
I guess that is why it was hidden in our storage room
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
75
Hey, I have a Stratix 8000 which have factory reset. When I power it on now the EIP Mod light flashes for about 10 seconds. Then all the status...
2,263
Hello Guys I had to reset a stratix 8000 to its defaults, but now it haves an alarm a port is flashing brown/green the message it has is not...
2,686
I have forgot password of console login When I am going to connect stratix-8000 through putty terminal,I have a username but password was given by...
1,719
I have a number of AB Stratix 8000 and 5700 switches which are passing all data but I cannot web into them nor ping them. these switches go into...
2,612
