Stratix 8000 model- 1783-MS10T
Ratan_shubha
Jun 2021
Hyderabad
I have forgot password of console login
When I am going to connect stratix-8000 through putty terminal,I have a username but password was given by sometime back where no one knows.
How to recover the password?
Please help
I too tried with that reddit post,but it didn't worked, present the switch is working,but I need configuration file to cross check the things
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
75
Hey, I have a Stratix 8000 which have factory reset. When I power it on now the EIP Mod light flashes for about 10 seconds. Then all the status...
2,259
Hello Guys I had to reset a stratix 8000 to its defaults, but now it haves an alarm a port is flashing brown/green the message it has is not...
2,683
I have a number of AB Stratix 8000 and 5700 switches which are passing all data but I cannot web into them nor ping them. these switches go into...
2,605
I was going through our storage area and found a Stratix 8000. I could not find an IP using an IP scan tool so I consoled into it. it appears...
1,503
