Stratix 8000 - IGMP Snooping
Andy Veitch
Oct 2012
Oxfordshire
26
Can anyone tell me if the IGMP snooping is enabled if the Stratix 8000 is used in a way straight out of the box using the factory defaults.
I have managed to program a spare unit for an IP address where I can check the box for IGMP snooping but the one online at the moment is factory default.
I would assume the snooping is enabled but just asking for clarification.
Andy
512151 - Stratix 8000/8300: Enabling IGMP Snooping
Access Level: TechConnect
Yes, IGMP is indeed enabled by default on the Stratix 8000 switches.
Regards,
George
Hello All, Please our powerflex 755 20G1AJD545AN0NNNNN runs for about 2 weeks then trips on F5037. I have checked the CAT6 cable that its not...
3,132
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
76
Hey, I have a Stratix 8000 which have factory reset. When I power it on now the EIP Mod light flashes for about 10 seconds. Then all the status...
2,265
Hello Guys I had to reset a stratix 8000 to its defaults, but now it haves an alarm a port is flashing brown/green the message it has is not...
2,688
I have forgot password of console login When I am going to connect stratix-8000 through putty terminal,I have a username but password was given by...
1,722
