Stratix 8000 Switch installation
asalunk
Aug 2017
Pune
Helllo,
I have to install new startix 8000 switch and want to communicate with 4 1756-EN2T module in 4 different chassis. How it will be done? How can i configure switch port IP address.
Thank you.
Did you try to open user Stratix User manual that has all steps to commission the switch including setting IP address.
The short answer is power up the switch and plug 'em in.
I'm afraid you will need to provide more and to ask a more specific question before we can help.
What have you done? What ins't working? Are all four on the same network? What are the four addresses? Is your computer part of the same network?
Managed switch needs to be managed. There is no reason to pay premium for it and not to set it up to take a full advantage of the managed features.
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
94
Hello Friends, How many ways we can reset stratix 8000 switch?
2,144
Hey, I have a Stratix 8000 which have factory reset. When I power it on now the EIP Mod light flashes for about 10 seconds. Then all the status...
2,282
Hello Guys I had to reset a stratix 8000 to its defaults, but now it haves an alarm a port is flashing brown/green the message it has is not...
2,700
I have forgot password of console login When I am going to connect stratix-8000 through putty terminal,I have a username but password was given by...
1,732
