stratix 8000 Trunk
yfcarer
Apr 2006
Tianjin
82
Hi guys:
I am trying to setup the trunk for one stratix 8000 switch port. Below is the commands I entered through putty:
- en
- configure t
- int F2/2
- switchport mode trunk
Everything looks fine, no error message.
Then I type command "do show int trunk" to verify, but found nothing is changed. Looks like the command not take effect.
Any idea? Precondition? Miss step?
Do you have link on that port? Cisco does not update the trunk command unless there is a link, at least on the products that I use.
Thank you. You are right, it can only accept trunk when I have the link on. I get it fixed as you mentioned.
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
76
Hey, I have a Stratix 8000 which have factory reset. When I power it on now the EIP Mod light flashes for about 10 seconds. Then all the status...
2,265
Hello Guys I had to reset a stratix 8000 to its defaults, but now it haves an alarm a port is flashing brown/green the message it has is not...
2,687
I have forgot password of console login When I am going to connect stratix-8000 through putty terminal,I have a username but password was given by...
1,722
I have a number of AB Stratix 8000 and 5700 switches which are passing all data but I cannot web into them nor ping them. these switches go into...
2,614
