Stratix 8300 Switch
DoubleL
Jul 2004
Georgia
47
Hi Guys,
I know there are some network gurus out there that can help me.
I have a machine network which includes a Compact Logix, 2 Powerflex 700s drives, 3 powerflex 40 drives, and a Wonderware HMI computer. These are connected to an unmanaged switch which is connected to a Stratix 8300. I am trying to set the Stratix switch up so that my network is viewed through the FA1/1 -4 ports and use the Gi1 ports for connection to an outside network with a different IP where I can access my network through a VPN.
I have two Vlans with one setup with My network ip which is 192.168.1.254 SN 255.255.255.0
Can anyone give me a way to do this in simple terms?o_O
I have tried for two days with no luck. My engineer has had this working but I'll be darned if I can make it work.
I have been trying to connect my computer to simulate an outside connection but cannot ping through to the machine network
Any help would be appreciated
Make sure the inter vlan routing checkbox is checked.
Also each vlan must have a default gateway configured for each vlan you wish to route
This will route broad vlan to vlan if you want only specific ip addys to route then you have to set that up in the cli interface which is a bit more involved if your not a classic Cisco nerd.
Hey everyone. I am trying to connect my Plant Switch (Stratix 8300) to the Business Core Switch. I am not an IT professional, so I am trying my...
4,523
Good chance I'm just overthinking this. We have an existing CLX with a 1756-ENBT that has no slots available and was on the plant network VLAN...
2,244
Hi all, Got a question that I'm hoping some networking gurus can shed some light on :) I have an application which will see a 1768 series...
2,851
Hi everyone. I have a Stratix 8300 router. Trying to setup VLANs for inter-VLAN routing. With the attached setup (screen shots of web...
3,573
i am setting up a network with a stratix 8000 and an 8300, im using the 8300 just as a router for the devices connected to the 8000, this link is...
10,077
