String AB variables in FactoryTalk
Romanr9999
Apr 2009
Buenos Aires
27
I´m here again with my dumb questions.
I´m using FactoryTalk View Studio 5.10 with an AB Micrologix 1400.
I need the user to update string tags defined in the PLC through a PanelView Plus 15000.
I tried using a String Input Enable object but it gives me a runtime error saying "The type of the value being written is incompatible with the tag´s type¨.
I can´t find a workaround. I know there must be one, since this is something basic.
The tag points to a string in the ML1400 (ST9:1.DATA).
I don´t find another way to define string variables in the PLC or another way to edit them in FT.
Thanks for your help.
I knew this was a dumb question although I never imagined it could be SO STUPID
It's neither dumb nor stupid. With some HMI's connecting to AB units you do have to use that type of addressing as they don't know what to do with the LEN part.
Besides yourself your question probably helped many others who are learning this sytem and to those in the future who ACTUALLY use the 'search' function.
I recently converted a PLC-5 program to Controllogix and using iFix as the graphic interface. I seem to have trouble reading a string and...
3,729
Hello Guys, Some time ago I wrote an ASCII protocol in C++ on a master PC which is sending a char string to a partner PC. The string contains...
16
8,559
Folks. I have a S7 PLC with a security program to monitor doors, temperature (analog), electric service voltage (logic). I have a Siemens TP070...
11,070
All, I am trying to reset timers when a Work Order change occurs. The Work Order comes in as a string and I am comparing it to a tag...
100
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
288
