String Comparison in SLC 5/05
but ascii string compare address must be a ST type. My string is store in A file. I get the string (just a description or name) from scada. but i need to equal these two strings which i get from scada.
But Strings in SLC´s has to be in ST Files ! Or in what files do you put your Scada DATA ???
Hello! I have review PLCS at least half a dozen times and it occurred to me I might be able to crowd source a solution for something I have been...
3,005
Hi, i am trying to compare a string value in an IF statement My string value is user defined string called Barcode_String max characters 26...
7,363
Hi There, I am programming a cmore EA9-T87 to gather the data and save on SD card. And this time I want to use barcode scanner to trigger the bit...
3,515
Hello all, I need to compare the first three digits of a barcode string to a known value. I have the string being pulled from the Serial...
4,789
Good afternoon to all. I'm new guy on this forum. I'd like to ask you for help with task like this: My boss gave me a program to modification...
12,937
