String example ???
macs_plc
Jan 2008
Nagercoil
120
how to input a string...
in FC4 -- delete string...
i have declared st---string[9]
when i include this fc4 blovk ob1..
its asking for expected data type -- IN : string...
what to enter in that ??? (like mw,md, or ?????)
What iam missing ???
There is a big clue on the screen shot you have posted:
Expected Data type: IN: STRING
You have to declare a variable to be of type string to be able to pass it as a parameter of type string.
Here's an example using a DB containing a string variable:
You cannot monitor string variables as strings, you have to monitor them as a collection of bytes and display them in character format.
nice one.....
one more thing is it possible to view date_and_time (dt) in "VAT" (both date and time) in same time...i tried but i can only view date or time at the same time
All, I am trying to reset timers when a Work Order change occurs. The Work Order comes in as a string and I am comparing it to a tag...
66
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
280
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
184
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
444
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
146
