Maybe I'm just missing the concept here but:
You are using a string datatype - a string is an array of ascii characters (text).
You are searching for bits on - that doesn't make sense with a string.
You seem to be focusing on the .Len member of the string - this is a DINT holding the length of the string. Examining its bits shouldn't be useful.
If you explain what you are trying to accomplish, I'm sure someone can help. I mean explain what you intend to accomplish in the real world, not how you are trying to use this instruction.
Mellis, I am trying to my string that I am receiving from a safety gateway. Once i get this string I want to compare each bit to 0. When it finds a bit that is 1 I need to pull that number and put it on my hmi with a message that says " Slave 15 is faulted"
