Stuck on a simple PLC programing problem
Poster, I'm glad you found an answer to your problem. I just wanted to add that because you are new to this software that the help utility in Logix can be a great resource to use. You said that you do not know the instructions very well. Logix help lists definitions and examples to use for all the operands. Most the time you can access specific help items by placing your mouse cursor over the topic and press "F1". Also the knowledge base on Allen Bradley's site offers many resources to use to download in PDF format (www.ab.com) I hope this will be a help and may save you some time on asking a forum for these simply researched answer.
As was mentioned before it is well appreciated by many of us that you seek answers as research not just to complete the asignment. It is ok to seek help in learning, not to ask for the answer.
Too many out there just try to get through thier training without actually learning the content, this leaves them unable to be effective in the workplace.
Hi Group See the photo. Will this work? I previously had the "contactor outputs used as inputs" tied directly to the IO DIG OUT coils, and what...
1,944
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
88
I'm using one TON (called SystemTimer) throughout a program that I change the .PRE given different conditions. I'm porting an IDEC ladder over to...
318
We have a keg check weigher that that lost a fight to a forklift. The scale was previously a Systec IT3000, which was the only PROFIBUS slave...
676
really strange issue. The panelview(2711p-T10C22D9P) will try to load an application and get stuck on "Starting Alarms". If I reboot the...
1,452
