Studio 5000, CompactLogix, and a VPN
agrajag42
Dec 2015
Bahstahn
17
I'm trying to connect to a 1769-L33ER CompactLogix PLC through a VPN.
When I'm on the same network, everything works great. I can download code within ~15 seconds or so.
When I switch to a different network and VPN in, it takes >20 minutes to download code, and then performance is very poor when I'm online with the machine (the mouse slows down, and it appears to be constantly thinking).
I'm connecting on the VPN with Local Area Connection 2, and obtaining an IP of 10.242.2.6, with a subnet mask of 255.255.255.252.
The PLC has an IP of 10.1.10.246, with a subnet mask of 255.255.255.0.
I used RSLinx to change the Ethernet driver to the VPN IP.
I am able to ping with average replies in the ~200ms range.
Netstat tells me I've got two active TCP connections from my IP (ports 61178, 61220) to the PLC (44818, twice).
I'm using Studio 5000 v21.00 Mini Edition
The PLC is a 1769-L33ER CompactLogix 5370 Controller Revision 21.11
I've done a bit of googling now, but haven't found anyone who had an answer or even the exact issue -- maybe my search terms are bad, or I'm a bad googler.
Anyone run into this?
Thanks --
/ethan
That's pretty much all you need to know. The network between the controllers is far too slow for good performance.
Are you using a VPN appliance, or a hosted VPN, or just an endpoint VPN ? Is this a corporate intranet, or is the Internet involved ?
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
480
I'm trying to configure the IP address of my compactlogix l16er-bb1b in Studio 5000. I need to set it to a certain address as I'm planning on...
3,239
I am trying to figure out the best way to get a moving average for an automated machining cell with cycle times of a couple of minutes for each...
1,718
Hi everybody: Is it possible to program the compactlogix 1769-L32E LOGIX 5332E v20 processor with this software? thanks
5,274
I want to create a lookup table AOI. Does anyone know a practical way to implement this? For example, The AOI will receive an integer and an...
2,368
