studio 5000 error when opening project
diat150
Mar 2006
Louisiana
1,475
Someone sent me a acd file to look at for them and I am getting the following error when trying to open it in studio 5000:
cannot overwrite existing project file because its security information is either missing or is inaccessible
Any idea what this means? My first thought is they have incorporated some type of security into the acd file. Any thoughts?
What version of Studio 5000 are you running and what version is the file? You can open the .ACD as a text file, the first many lines will tell you revision history in plain text, the last instance will be it's current version.
I should mention that I opened it with Notepad++, not sure what Notepad would think about it.
edit: notepad displays it the same as ++
Solution that worked for me
Restart RSLogix, while holding CTRL & Shift until it has completed to restart completely
worked for me !
Knowledge Base # 512161 on Rockwell's site
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
384
I get this error every time I install Studio on my new laptop. Any help is appreciated In case you cannot see it, it says... "The installation...
281
Hello, this is my first post after being a long time creeper on this forum. I am experiencing a fatal error any time I attempt to print to PDF...
400
Hi I have hms-en2mb-r module . When i configure and go online the module is faulted with error code 16#0009 and addition code 16#0001. Is there...
739
Hi, During Activation Rehosting(with Internet) of Studio 5000 there was an connectivity error which caused my License to be removed from laptop...
620
