Studio 5000 Make your own BCD?
LoganB
Apr 2017
Michigan
607
Studio 5000 v24.11 on a 1769-L33ERM
Pretty simple question today! I have a piece of testing hardware with four outputs wired to four inputs on my PLC. The testing hardware sends different BCD values to the PLC based on the test result. I want to convert those four inputs into an integer value in the PLC.
I know I can brute force it with 16 lines of logic, one for each possible outcome, but is there an easier/shorter/neater way to do this? Haven't had my coffee yet this morning :angr:
TIA!
BTW, I already tried to directly activate bits in a DINT and that didn't work.
Code:
   Input.0                        INT.0
The outputs don't activate...
However, upon further examination, the outputs DO activate once you put a JSR in place. :oops:
Now off to get that coffee
I am lost, are you done or still asking for another solution vs 16 rungs?
In case you need solution:
If input 16 bits, output 16 bits (INT) then use: COP (Input, Output, 1)
If input 16 bits, output 32 bits (DINT) then use: BTD (Input, 0, Output, 0, 16)
The inputs will directly activate the bits of the INT in the program, so I have my solution. I had my solution before, I just forgot the JSR. You'd think eventually that little mistake would go away with experience, but somehow it keeps on sneaking back into my life :ROFLMAO:
Good Evening , I purchased Studio 5000 Standard a few weeks ago . I know Studio goes down only has far has version 20. I need to go down to...
4,691
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
267
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
121
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
125
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
76
