Studio 5000 v31 or v32 or v33
What Version of Studio 5000 Should I Upgrade to?
  • Try to stay with v31
    Votes: 1 9.1%
  • Upgrade to v32.03.01
    Votes: 7 63.6%
  • Suggest v33
    Votes: 3 27.3%
  • Total voters
  • Poll closed .
celichi
Apr 2008
Greater Toronto Area
415
Hello Everyone,
Is it a good idea to make the switch from 31.011 to 32 or 33?
I am currently using 31.011 on all of our 5370 L33 or L36 processors.
I went from V20 to V31.
Doesn't look like I am going to be able to hold out till V42, I am being nudged towards 32.
I had heard 32 was problematic?
What version should I go with?
1 - Fight to stay at version 31?
2 - Upgrade to version 32?
3 - Propose version 33?
Thank you.
Paul
I'm not experienced with those latest version of studio, but I am very intimate with the golden rule of maintenance.
With that said, I believe there was a specific product advisory related to version 31 that can be very serious. I don't recall the details or whether they're resolved in version 32.
I've been commissioning a large system for the past year on v32 w/o issues. L8x
Do you remember what it was? I’ve been on 31 for a while now and haven’t had any major issues.
To answer the OP, check the release notes and see if any of the higher releases are of any use to you. If not there is no real reason to upgrade unless there are issues like Okiepc is referring to.
I agree with BachPi, 20, 24, 28 were really good. I've had good success with 30 and 32, but I didn't use many AOIs, just basic ladder programming. Never tried 31, I was told to skip that revision from another controls guy.
But if you have a project or job that requires 31, then you have no choice but to use it or convince the customer to use 30 or 32? If you doing just basic programming, go for 32.
I would move to V32. It is much more stable that V31. I get fatal errors quite a bit with V31. Just my 2 cents.
Hi everyone: I need to upgrade my Studio 5000 to from V31 to V33, but when I try to download from Rockwell PCDC, I only have the option up to 31...
1,400
Guys, beating my head on a wall here. I have two simple date-times and I want to find the oldest. Are there any better ways to do this beside a...
3,503
When starting installation of Studio 5000 I get option to install it on C: disk as default. When I change it to disk D: I see that it still wants...
2,951
I am trying to add datalinks to a couple of PF525 drives in studio 5000 V31 in order to use the PlantPax AOI. I am offline with the PLC and the...
3,698
Hi, I've been working on a project for a couple of weeks now using Studio 5000 Logix Designer (v31 project, also have v32 and v21 installed)...
2,204
