Studio 5000 v32 SQI instruction problems
Carl985
Aug 2021
Shropshire
Hi folks I'm currently upgrading a control system that's nearly 20 years old from a 1756-L61 last programmed using version 20 logix5000 to a 1756-L82e using v32 studio 5000/logix designer.
I'm having issues with the fault handler routine was working with no issues in logix 5000.
The faults are stored in R_Fault1 dint(4) array they are the copied using cop source R_Fault1[0] dest D_FLT_Code1[0] length 4 then it passes through an SQI instruction which sets the relevant fault. My issues is that for every fault in the first word R_Fault1[0].0 to R_Fault1[0].31 its works fine but for anything else eg R_Fault1[2].22 it just skips past it. As I said earlier it was working fine in v20 its just started happening after changing to v32 I have attached a picture of the SQI. Thanks for your advice in advance
Update
Hi folks just an update: so after my problem bugging me all night I popped into work on Saturday afternoon and started having a play around and I found out the following.
The sqi instruction is not comparing the source and array unless I cycle through the length as follows, if I have a fault in dint 1 when the length is set to 4 it will work once then if I set the fault dint back to 0 and then trigger the fault again the sqi won't compare again until I change the length from 4 to 1 etc does anybody no why this would be
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
148
Got a repaired laptop back from warranty and loaded it up with all my software, unfortunately with my version V32.03 Studio 5000 I cannot change...
199
Hi, I am having issues with Studio 5000 v32.02 and connecting to a 523 PowerFlex drive via Ethernet. My network consists of a 5380 CompactLogix...
1,783
installed v32 on server 2016 and when i open studio 5000 it freezes on the logo screen any ideas to why
1,682
I am a big fan of developing in Logix Emulate when I don't have access to a live PLC. That said I am running into an issue with not being able to...
1,545
