Studio 5k: How to 'trend' strings?
PeeLC
Oct 2018
Krypton
30
I need to see what changes have been made to a string over a period of time. Is there a way to do this without having to start a DDE link in Excel?
Thanks!
-PeeLC
You could monitor the string for changes by comparing it to the last version and when the change occurs, deposit it into a FIFO buffer, then re-establish the changed string as the "Last" string.
I would create a UDT with the string and a date/time stamp, and use that as the entry into the FIFO.
Studio 5000 how do i shrink the Trend screen down or split the screen so i can see the Ladder and the trend?
403
Hi Folks, I am trying to trend in Logix Designer an element of an INT[223] input data array. For some reason, the "add" button is greyed out. I...
2,213
Good morning, 1- I am finding good use out of the Trend feature in Studio Logix 5K. Is there a way to export the graph into a pdf automatically...
2,328
I just added a historical trend to my application and cannot get the display to show any data. I did the following to create it: 1. Created a...
2,101
I am trying to simplify procedure of adding/removing FTHistorian Tags by the operator. Oryginally, FTStudio allow operator to click on the trend...
5,138
