Stumped. DL06 Address "B"
Tronador
Jul 2019
Quebec
Anybody have any info on the address prefix "B" used on the DL06 units?
I am working with 4 Direct Logic DL06 units (D0-06AR) connected to each other via ethernet on ECOM-100 cards. Some of these units are also configured with extra modules, analog input (F0-4AR2DA-1) and thermocoupler (F0-04THM). I have been tasked with understanding what an existing program is designed to do and I am stumped by some of the addressing. Within the code, Each PLC program uses multiple addresses using a "B" prefix as well as a number with a decimal. For example: B3000.0, B3000.1, B3000.2, B3200.1, B3200.2, etc.) I cannot find the standard use for this B address anywhere in the main manual or those for the expansion modules.
Anybody ever seen this used before?
Thanks in advance.
This allows individual bit addressing with a normal 'V' word. For example B3000.0 addresses the lowest bit of V3000. In the DL06 manual search for Bit-Of-Word instructions.
Yes, this makes sense, and I've found the references to bit-of-word in the manual. Thank you for your assistance, Bernie!
Anybody have any info on the addressing prefix "B" used on the DL06 units? I am working with 4 Direct Logic DL06 units (D0-06AR) connected to...
1,669
i have a hwk question that i cant get fixed right. attached is the jpeg of what i have done soo far and question is attached as well any help is...
2,295
Hello: I have a micro820 plc with a Spectrum Controls 2080sc-IF4 analong module and a Prosoft 800 SMS module. I have 3 4-20ma pressure sensors...
1,221
Good Morning Everybody, I'm using RSLogix500 and programming a Micrologix 1100. I define all my outputs using B3 data file and reference those...
1,923
I am having a problem with replacing a AB pico controler. It is a 1760-L18AWA-EX B The old one was an A. I have loaded the program and when I thy...
1,440
