So one of the problems you’re going to run into is that you will have overlapping outputs (lights). For example, on rung 1 you have output O:2/0 come on when the timer is less than 140 however you also have output O:2/0 come on when the timer is less than 220. So when the timer is at say 100, 100 is less than 140 and 220 so both outputs will be on. You could add more “GRT” blocks or you could use EQU blocks instead of GRT blocks and MOV blocks instead of outputs. Given that this is homework, instead of my just creating logic, I’m going to ask, do you see what I mean? Keep in mind that the outputs are bits in a word.
