Stumped on PLC hwk question
chui84
Mar 2016
houston
i have a hwk question that i cant get fixed right.
attached is the jpeg of what i have done soo far and question is attached as well any help is greatly appreciated.
  • Traffic_Lights_Spec.doc
Thanks for the quick reply.
well i am confused on how to implement
LEQ 12 WALK_EW 12 seconds Goes OFF 2 sec before R1 expires.
and
LEQ 24 & GRT 12 WALK_SN 12 seconds Goes OFF 2 sec before R2 expires.
plus my green lights both turn on on both sides causing a crash.
Your WALK_SN & WALK_EW look to be implemented the same way as your 6 traffic lights.
Use the ACC as LEQ 12, and the other at (GEQ12 & LEQ24). The latter being a series argument same as rungs 3 or 5.
Both would need assigned a separate Output channel
So one of the problems you’re going to run into is that you will have overlapping outputs (lights). For example, on rung 1 you have output O:2/0 come on when the timer is less than 140 however you also have output O:2/0 come on when the timer is less than 220. So when the timer is at say 100, 100 is less than 140 and 220 so both outputs will be on. You could add more “GRT” blocks or you could use EQU blocks instead of GRT blocks and MOV blocks instead of outputs. Given that this is homework, instead of my just creating logic, I’m going to ask, do you see what I mean? Keep in mind that the outputs are bits in a word.
yes....with separate outputs. Your assignment didn't really give you outputs to assign, but a "walk" sign would be a separate output for each. Presumably 0.2/3 and 0.2/7
Typically, try to place one output per rung, with all arguments for that output before the output. Some have put the same output on multiple rungs, but that is typically bad program design. Simple rule to follow makes following a program for troubleshooting much easier.
Double make sure that your arguments before the "event" output, match your assignment. There are some mistakes in there.
I'll give you a little teaser.
This one is stumping me, it might not even be possible. I have machines running PLC 5's and machines running ControlLogix processors. When a...
5,555
I am in deep trouble! If anyone can help me figure out how to make this one output work using the real time clock to control when it is true and...
32
13,413
Anybody have any info on the address prefix "B" used on the DL06 units? I am working with 4 Direct Logic DL06 units (D0-06AR) connected to each...
1,771
Anybody have any info on the addressing prefix "B" used on the DL06 units? I am working with 4 Direct Logic DL06 units (D0-06AR) connected to...
1,702
Hello: I have a micro820 plc with a Spectrum Controls 2080sc-IF4 analong module and a Prosoft 800 SMS module. I have 3 4-20ma pressure sensors...
1,227
