Suspect Database DB SQL Server
userxyz
May 2002
any
2,768
Hello,
I have a DB (22 gigs big) that is suspect and not working anymore.
I found this repaircode on internet:
Code:
EXEC sp_resetstatus SOADB;
ALTER DATABASE SOADB SET EMERGENCY
DBCC checkdb(SOADB)
ALTER DATABASE SOADB SET SINGLE_USER WITH ROLLBACK IMMEDIATE
DBCC CheckDB (SOADB, REPAIR_ALLOW_DATA_LOSS)
ALTER DATABASE SOADB SET MULTI_USER
The query is now allready running 1 hour and 30 minutes. Is this normal ? And will the DB be repaired in this way ?
Anyone with SQL experience can help me out ?
kind regards,
Gerry
Code:
DBCC checkdb(SOADB)
In the following code, you did not set the database into Single user mode. The second thing is, here is the chance of data loss because you are using DBCC CHECKDB option with REPAIR_ALLOW_DATA_LOSS option.
I will suggest trying the free version of this SQL database repair software to fix Suspect mode issue.
Good Luck!
fix suspect database
It's quite common that the database is suspected, the best way is to always keep a backup. I have met such an issue, and I used the Bitwar to rescue my suspect database, you can also have a try.
Hi All, I have been working on a home rig that has a 1756-L61S and the relevant safety partner. Have owned for a long time and never had any...
2,205
Hi guys, I have a machine that has been acting up a few times lately. It looks like it "forgets" it's position. The position comes from a...
1,443
I have a 1769-SDN DeviceNet scanner attached to a MicroLogix 1500, flashing 75 63. (No traffic, node 63). The highly suspect part is that the...
2,400
I currently offshore on a platform doing a pre-start check of some equipment and I have a pressure xmitter that's causing the Underrange bit to...
3,569
I’ve been tasked with extracting PLC (logix 5572) realtime data, storing it in a database (anything compatible with our data) and displaying it in...
41
