SW Conversion of Siemens S7 PLC to GE PLC
ranjan
Sep 2011
INDIA
Hello
I am looking for a solution as to how to convert the PLC code written in Siemens S7 to the GE PLC format (Proficy Machine Edition).
Any conversion tool , if available , please let me know.
Thank you
Ranjan
The latest PAC systems in the GEIP Proficy ME families will import .xml files, does the S7 system export them? It may give you a start.
From experience I have noticed that it is usually more productive to work from a good sequence of events and start over though. When 'converting' too much time is spent 'learning' the original programmers technique and attempting to merge it with the new programmers way of doing things.
I agree with RussB.
I have done this a few times between different PLC platforms, and I was sorry every time.
A lot depends on how clean the original program is and how good the documentation.
Sometimes you can have a program written by a 'committee' which can be a lot of fun to decipher.
Converting the code is only phase 1, the interesting bit is commissioning.
I suggest you learn the process and do your own program for the new PLC. You will know
how it works and your commissioning time will be less.
Dear Experts. I have a CPU 315-2dp Siemens PLC which is communication between mistubishi fX-3U Series mistubishi is giving me AScii String data...
5,953
hi everybody Iam converting s5 to s7 but ihave facing some problem in s5 system 95u cpu was used and it has a 9pin port, through this port it...
4,777
Dear All, I have a Allen bradley program designed in Logix 500 with SLC5/04 based hardware.Now we have a new client asking for siemens PLC for...
11,549
Anyone know how I can convert DTL to DATE type? This rung is trying to determine if the system is in calibration by subtracting the current date...
600
I have converted a Siemens OP7 program to a new Delta DOP107BV. It is all working as expected except for the timer values. I am using MW36 as the...
956
