S5to S7 conversion siemens plc
nibay
Jul 2009
delhi
42
hi everybody
Iam converting s5 to s7 but ihave facing some problem
in s5 system 95u cpu was used and it has a 9pin port, through this port it used as a interrupt input.i want to this in s7 plc(314c2dp)in first channel inputs,I can't doing this hardware configuration and icant understand how i use this input as a interrupt in s7 plc.
kindly help me..........
:mad::mad::mad:🤞🏻🤞🏻🤞🏻
nivash
thanks
L D[AR2,P#0.0],
can U tell me how interrupt input works.
this system is used in a cigret plant in tobacco cutter machine and this interrupt input feedback coms from a sensor to measure a lenght of knife.
A HW-interrupt stops the cyclic program from OB1 at a certain point 'a' and then excecutes OB40 one time only. After the excecution of OB40 the cyclic program from OB1 will continue from point 'a'. Point 'a' can also be inside an FC, FB, SFC or SFB. Off cours you need to program the response of the HW-interrupt inside OB40 and download it to your cpu.
For more information you can also search the forum.
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
214
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
97
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
128
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
107
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
286
