Swithched Reluctance Motor
vikas_latiyan
May 2009
Bangalore
Hi All ,
I am having a Old 90 KW Switched reluctance(SR) motor which i am trying to run by ABB Drive(ACSM1) in DTC mode ..But i m not able to complete the id run.Motor able to run in V/F mode.but my application is a Stamping press and i need to run it in Pos loop i.e. DTC mode.
is it possible to run a SR motor by a DTC/PWM drive.if noy y..
Please help ASAP as i m stuck on site.
...vikas
I have a retrofit project, and need a signal conditioner for one of the old-style variable reluctance/inductance sensors that were used (by...
3,021
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
260
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
147
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
347
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
216
