Symbol LS3408 scanner RS232 to Allen Bradley 1769-ASCII Card
Mister Mac
May 2013
Longford
19
Hi Folks,
Hoping someone can help me out here, I am trying to configure a (Zebra/Motorola) LS3408 barcode scanner with an RS232 interface to read barcode information into an AB compact logix L24ER containing an 1769_ASCII card.
I have tried the scanner on another AB PLC type (1769 L23-QBFC1B) and it works fine. The serial port config setup is different though between the two PLCs so it is not possible to replicate exactly.
I have attached a copy of the pin-out info both for the card and the scanner.
LS3408 1769 ASCII Card
TXD 4 -------- 2 RXD
RXD 5 -------- 3 TXD
RTS 6 --| 7 RTS --|
CTS 7 --| 8 CTS --|
Pin 6-7 jumped on LS3408
Pin 7-8 jumped on 1769
Note:power connection must be supplied separately.
I would start with the above pinout based on your drawings. If it does not communicate, possibly switch the TXD and RXD signals.
Hope this helps you out.
Regards,
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
104
I was looking for this function, so that i doesn´t need to do it in the PLC. If there are an alarm in the alarm list, i want to flash the...
538
Hello, fairly new to plcs I’m tasked with installing a PE to a micrologix1200, in the attached picture I/14 is the PE I’m installing it’s going to...
953
Hello Thank you all for your support. I am actually experience same issues with TIA portal V17 update5 as well as V18. The problem is with the...
807
Hi all, I've inherited someone else's program and can't for the life of me figure out his use of the # symbol in one of his structured text...
1,924
