Synchronise PLC clocks
userxyz
May 2002
any
2,768
Hi, (siemens question)
I have several PLC's on a Profibus network. This network is connected to my PC. The PLC's are connected via CP's to that network, there is also a local network to ET200 stations.
My question: I would like to have 1 CPU as a Date & Time Master, can I send the 8 bytes of the clock to other CPU's ?
You can also synchronise the clock of a cpu by means of it's MPI.
Go to the HardWare-Configuration of the cpu and choose the tab 'Diagnostic/Clock'. There you can synchronise the clock
- in the plc
- via MPI
You also can adjust the synchronisation-mode of the cpu
- slave: clock will come from another cpu
- master: cpu will determine the clock
Our topology is Wonderware InTouch 7.1 (soon to upgrade to 10) and we have several independent Modicon 984 processors on several modbus+ hwys...
1,741
Hi, These is an already working plant with HIMA PLC that has a Siemens Comfort Panel HMI connected via Ethernet. HIMA is type 51QHS. I want to...
293
Hi all, i have only just recently started using AB software so im getting confused in a few places and dont know much, i do find it hard to find...
1,646
GitHub Link: Open Industry Project This is a side project I've been working on for some time. The goal is to provide an open platform for...
52
Dear All, Currently i'm working with Endress Hauser flowmeter and AB PLC and try to integrate with 2 items. Flow meter spec using is Promass...
70
