Tacho of DC-drives
Plc_User
Dec 2005
Belgium
317
Do tacho's of dc-drives always reverse the output voltage when rotating in the reverse direction? This is because I wanted to reverse the rotation direction of a dc-drive. So I reverse the connection of the armature and the connection of the tacho. But the the drive immediately ran up to maximum speed althoug the setpoint was low.
Yes, a DC tach is simply a DC generator, if you reverse the direction the polarity will change.
More details, type of drive etc.. and maybe we can help you out.
The drive is a Siemens Simoreg 6RA211 two phase power supply, I only see one thyrisor bridge (4 thyristors), so I believe its 2-quadrant (one direction delivering power and braking). Looking at the drawing of the connections and the internal build up of the speed and current controller, it seems that the tacho input always has to be positive and the resulting reference should be negative if the motor has to run. If the resulting reference (main and additional) is positive I suppose the drive is stopped. This because the - of the speed opamp is connectied to the addition of refence and actual value and the + is connected to zero voltage.
some tachos fitted to d.c drives do not reverse the output when direction is reversed and are usually a.c rectified devices whichare a cheaper option than a d.c tacho technodrive motors for example used to have true d.c tachos as an option at greater cost
Thanks Mel, but these are standard Siemens DC-drives, the exact type I don't know. I only know they give 60V at 1000 rpm.
tachs and DC drives
You could try a full wave bridge diode of the proper voltage/current range to keep the polarity the same at the drive input from the tach.
Cheap and dirty may work.
You may well have an AC tach. This would be particularly true if the motor nameplate says STAB SHUNT or COMP SHUNT making the motor basically a unidirectional motor.
Somewhat off topic but wondered if anyone could give me a place to start. Last year a customer wanted a very rough and ready and cheap speed...
2,512
Can anyone reccommend an overspeed relay driven from a tacho? (It needs to protect in both directions)
2,331
Hi all, Slightly off topic question. I have a web postioning unit that moves a web, in a printing press, sideways (to 0.05mm accuracy) to...
3,749
S
hi can any one please suggest a heavy duty tacho meter that can be connected to plc's analog input, I need it to be similar to a rotary encoder in...
3,202
hello,im looking for a tacho loss relay to substitute a broken one in a machine.i cant find the original make,and looking around there doesnt seem...
3,838
100110010101
