Tag Addressing with ABB COMLI and Red Lion G310
rberghammer
Mar 2008
Silverthorne, CO
23
Hello Everyone,
I am trying to make a Red Lion G310 HMI communicate with an ABB AC800M PLC. This is my first time dealing with an ABB processor, so I am having some troubles.
I was wondering if anyone has any experience setting up tags in an ABB PLC to communicate over a COMLI driver. From what I can gather in the help files, I believe I need to assign each tag a data register in the "Access Variables" table. Example: "%MX8#100" would be bit 100 (octal). But I don't know if I can just start assigning these registers wherever I want, or if I have to follow some rules.
Any information or alternative ideas would be appreciated.
Looking for answers
Hello!
Did you find a solution to your problem?
Im struggeling with the same when im using a Beijer HMI to my AC800M. What addresses does the I/O's have when using COMLI standard.??
Hope someone has got an answer quickly :)
Greetings, How should I refer the variables that come from Unity Pro as tags in Citect SCADA 2016? For instance, I want to import some tags...
1,983
Hi, How to define Siemens(S7-300 via MPI) plc tags in weintek HMI Mt8102? I know Communication is established but i am not defining addresses...
1,760
Hi, How to define Siemens(S7-300 via MPI) plc tags in weintek HMI Mt8102? Communication is established but i am not defining addresses correctly...
1,068
I would like to read the system tags (%S, %SW) from a m340 processor into my HMI/Historian. I am using kepserverEX OPC server and it uses...
1,812
I'm working with a FactoryTalk View program that I've never worked with before. I'm trying to find where the tag is linked for a button that is...
19
6,020
