FactoryTalk View Tag Addressing
The Global Object definitions do not have to have values entered. In post #2 we can see it is not being used. You can use a parameter file or parameter list instead.
Parameters are "plugged in" when the display loads or is refreshed. Check the button/object that opens this display. Look to see if they are using the parameter list/file option.
I don't know if you are using ME or SE but you could even have a button on that same display that uses the "display command (SE) or a GoTo button (ME). This would act to refresh the display using a different set of parameters.
OG
OG
I'm using ME. I appreciate the response. This makes a lot of sense now. I'll check the button that loads that screen and see what is going on and if parameters are being loaded.
*Edit - You're correct, this seems to be where it's being generated. Now I just need to understand exactly what this file is doing.
Thanks again.
I totally understand this methodology of programming, I use it often with Siemens Functions. I'm still struggling to understand WHERE the 2nd part of the address is called. #1 is obvious to me, it's basically the driver/link to the PLC. The #4 is where I'm still confused. I understand you can have multiple instances of the same global object, I'm just not seeing where the bit that it's toggling is called out. I really hope I don't seem as stupid as I feel right now, I'm just not seeing where that tag is set per instance.
Thank you guys for all the help. It's been a while since I've been out of my comfort zone, hence the lack of posts over the years.
The #4 is your PLC tag for your button. You are correct that the #1 is the link to the PLC. So where I work I have global objects and I have some screens that have the same global object duplicated 15 times on the same screen yet they all display different information because in this case that #4 parameter value points to different buttons.
Thanks for all the help guys. I don't know why, but I had to uninstall and reinstall to be able to see the Global Object parameters in the instance. I greatly appreciate the guidance and patience.
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
293
Hi All, I'm trying to look into if it's possible to get FactoryTalk SE to build a process log report, recording various tag values at a poll rate...
579
We are cutting over a PLC5 to ControlLogix and we ran into some issues with the HMI (FTView v10, Network Distributed). We found that after...
950
RE: FactoryTalk View Tag Browser Datatype - UNRECOGNIZED Hi All I have a new install of FactoryTalk View SE 12 with the May 2022 patch rollup...
3,267
Hi All, Does anyone know that how to monitor tag value during the client file is running? I don't want to create button with animation to find...
1,454
