Tag browser freeze - FTView V12
chavak
Jul 2002
752
Hi Guys,
I know it's not a great product, but using it because of no choice.
Was working on V10 without much gripes. Then came V12.
I'm facing tag browser window freeze [ takes it from a few seconds to a couple of minutes to unfreeze]. Checked the knowledgebase, nothing shows up. It happens in both offline and online.
Anyone encountered it, any workaround?
Thank you
BTW, the PLC is a CompactLogix 5069 L320-ERM
The FactoryTalk View Tag Browser hanging after opening was a thing for a while. There is a TechConnect Level Knowledgebase doc
ID: BF13216 | Access Levels: TechConnect
FactoryTalk View Studio: Tag browser opens but freezes, does not respond to clicks
The issue was listed as fixed in CPR9 SRx Patch Rollup dated July 2021 or later. Do you have that Patch or later installed?
The workaround before it was fixed was to Alt-Tab away from the Tag Browser dialog window, then Alt-Tab back to it.
Thank you Mike,
I'll check out the tech connect document.
Good to know about the Alt Tab as well
Thank you
Does anyone know how to make the FT View Tag Browser Column with persistent? Every time I open the browser, I have to resize the Name column...
644
I just had to move my Rockwell VM over to windows 10, so I have a new setup with versions 32-34. I'm having a weird issue where the columns in the...
630
RE: FactoryTalk View Tag Browser Datatype - UNRECOGNIZED Hi All I have a new install of FactoryTalk View SE 12 with the May 2022 patch rollup...
3,311
I've put in several tickets to Rockwell about this issue since last December and I keep getting redirected to this worthless knowledgebase article...
1,620
I've suddenly run into a very slow response to tag browser mouse-clicks in RSVStudio. The version is 11.00 with the latest patches installed...
1,358
