Talking to a SLC-150 in Virtualbox
Nov 2013
Michigan
532
I have a Virtualbox set up with an installation of FreeDOS 1.1
I have a SLC-150 I'm trying to communicate with via the 1745-PCC. My host machine is a laptop with Windows 7 64-bit. The serial port is on a port replicator (it plugs directly into the dock port so it's not a USB adapter).
Here's my issue. I can connect to the SLC-150 sometimes and can upload/download. I can even monitor the program...for about 10 seconds. And then I lose comms and can't get it back. I don't know why. DOSBox won't work at all, and yes I set up the serial port. I did try it with a USB to Serial converter as well and I have the same issue. Any ideas?
Not sure of your cable and USB adapter but the one I sell (and manufacture USB or serial) works good, this is the procedure I have my customers use
http://www.plccable.com/communication-support/ (3rd down from the top)
Send me an email and I can send you the links to download everything needed (other then the cables) [email protected]
Then by trying my setup with your cables you will be able to see if its the cables or your setup.... I have never used FreeDos, I use DosBox (also free) also the version of PCIS that I use also works good
Hope that helps
Mark
Hi, I have 6 SLC 5/02s on 485 network. One of the processors faulted. I've replaced it and downloaded the program into the replacement using the...
1,628
I am doing some project work in a plant with older equipment which will NOT be updated. They will buy a new line in the near future so are using...
3,975
Happy new year one and all. Have a project i am working on at the moment and having a bit of issues. * Have a panel view 600 talking to a...
2,216
i have a 505 and a micro 1100 on the same same network. how can i set an output on the 1100 when i have a bit to go high in the 5 05? thank you:hmmm:
1,584
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
169
